As Jay Leno said, when he drove the initial Aptera iteration, "If you got in this vehicle and you didn't know it was three wheels, you'd think it was four wheels"
@barry Doesn't every 2+ wheeled vehicle? I rarely see potholes that are small enough to straddle with a 4-wheeled car. Speedbumps and other such obstructions usually cross an entire lane. I usually change lanes to avoid exploded tires, bags of trash, boxes or pieces of wood lying on the road - or slow down and drive around them.
I'm not sure about the comfort aspect, but it should definitely help with efficiency. Ridge-Riding is a well-documented hypermiling technique in existing hybrid and high-efficiency vehicles, and I assume the same benefits would apply to the Aptera, with the third wheel riding in a typically higher, drier and less worn part of the road.
That reminds me of another reason motorbikes favor the left track: It's drier because the car ahead of you pushed the water off with its tires, & there's more evaporation due to the heat of all the tires. This may not match someone's documents, but it matches real world results.
Riding a motorcycle, I've never noticed lane position making a difference in ride comfort on paved roads. We favor the driver's side wheel track for other reasons, including vision, visibility, & traction (less oil), but not ride comfort.
Just guessing but I think the center wheel would run smoother, as the ruts created by trucks would not be a factor for this wheel...
