Aptera specs the efficiency at less than 100Wh/mile. Level 2 charging EVSE have a max load of 16A, 32A or 40A. This means adding 40miles/hour, 80miles/hour or 100miles/hour (rounding up). This is quite excellent for home charging. Is there a figure yet for the max charge rate available on the road? For example, time to go from 20% to 80% of max charge.
Solatubes that vent? What will they think of next!
Interesting. Does Plugshare and others help with your above route charging issue, with the residents that allow charging too, along your route?
🤔 the 60 kWh Aptera may be my best choice for my AZ to NJ and CT run.... and. plan using Chargehotels (for overnight stays) and Plugshare as my guides.
My garage/ home is ICF construction so that helps with the heat/cold issues... the problem with a hot ICE vehicle returning after a hot drive in the desert summer is the garage gets and stays hot if I close the garage insulated door right away. Not the same issue with an Aptera
It's strange because I-20 is the direct route from Dallas to Atlanta yet it has almost no charging infrastructure across three states. I-55, as well, links Chicago to NOLA and the 400 miles through MS are unsupported.
CCS ranges from 25 kW to 350 kW - in Plugshare it's best to filter for connector type. You can also search via Google Maps or use Electrify America's own map.
No, actually, range loss is NOT due primarily to cabin conditioning: All EV batteries have an optimal operational range between 50 F and 80 F with the most effective charging happening when the pack is in the mid to upper 70s. When ambient temps drop into the 50s and lower EV batteries don't accept as much power when charging and deplete their charge more rapidly. The same happens when the ambient temperature is above 80 degrees. When you add cabin conditioning to that equation the numbers drop even more quickly.
I can see this even with the relatively small pack (18 kWh) in my Clarity: Its range is greatest in the spring and autumn when the weather is mild with temps in the 70s and 80s. By keeping the car plugged into the L2 EVSE in my garage I'm able to precondition the cabin using grid, rather than pack, power: There's nothing like getting into a cool car when the thermometer passes 98 in the summer - or a warm one when the temp drops below freezing! Because of our intense humidity, though, the AC runs pretty much year-round...
On the up side, though, most EVs that have liquid-conditioned battery packs will use grid power to heat or cool the pack to its optimal temperature for charging. Teslas, for example, begin to adjust the pack's temperature when they know you're heading for a Supercharger so that the vehicle arrives at the station already at the correct temperature and won't need to heat up or cool down for charging to begin.
Take a look at abetterrouteplanner.com or the Tesla route planner to see how they lay-out charging stops: It seems that more shorter stops is better than fewer longer stops - rather like those ICE drivers who never allow the fuel tank to drop below half!
You will be able to charge with 120v and the solar at the same time. The solar has a direct link to the battery pack.
From the sun, you get up to 44 miles per day (depending on conditions, time of year and where you live). From a 120volt outlet you get 13 miles an hour or about 150 miles of charge overnight. At roadside charging stations you'd likely get about 100 miles in 10 minutes.
L2 and L1 charging depend upon the capacity of the internal charger more than the amperage of the power provided. Right now most AC internal chargers are in the 3.2 to 7.2 kW range. The 6.6 kW charger in my car will fully charge its 18 kWh battery (13 kWh useable) in 2.5 hours on Level 2 and 12 hours on Level 1. BTW, some Tesla Wall Chargers are capable of 80 Amp Level 2 charging.
There were several answers on this matter provided in these old answers on the Wefunder site for Aptera....
Daniel Watkins was kind to save, in WORD for us....Ask a Question section from the Wefunder site for Aptera , which could be handy to search in WORD:
https://mega.nz/file/cwEAGQSD#5D5xMF93QgZ34nWDW5IW3LWcI-FgrJ8oWl_bo5GHhnY
Perhaps you scan through the answers provided, to help, until the upcoming reveal of the Development Vehicles confirm reality.
I hope that helps
