I had a look at the website of #Elaphe today and I must say I am impressed! They will provide #Aptera with a total turn-key solution wrt to wheel motors, the controls and instrumentation requirements.
What was an eye-opener is that this company would actually be able to provide a complete solution to convert a normal car into an EV as their in-wheel hub motors will fit into the cavity of a normal size tyre rim on the inside. You can then throw out the gearbox engine and most of the drive mechanisms and have a high performance EV!
Brilliant work #APTERA for finding these guys!
EDIT: Only found this other post on the forum on the same subject:
https://www.aptera.us/forum/aptera-tech-questions/wheel-motors
Contains videos and lots more comments.
barry.hendriks wrote "convert a normal car into an EV ... You can then throw out the gearbox engine and most of the drive mechanisms"
My thoughts exactly! Throw out the differential, half-shafts/CV-joints, & of course the gas tank. Just add batteries & hook up the motors to the cooling system. Individual-wheel traction-control acts like a limited-slip diff, & AWD is easily attained.
Just like Aptera did!
This Aptera Instagram photo indicates they are using the Elaphe M700 hub motor.
Aptera on Instagram: “Parts are filling the shelves! Thanks, Elaphe!”
Very interesting. I am guessing that the Aptera will be using the liquid cooled S400. We have been using in wheel motor designs like this on motorcycles for years, but none had integrated the brake into the system. Thanks for sharing.
