In order to make the Aptera affordable to the widest possible consumer base, I recommend that battery packs be available in multiple sizes, e.g., 350 miles (32 kWh), 700 miles (64 kWh), and 1000 miles (100 kWh, which I frankly think is overkill). Also, given the very low WHr/mile efficiency of the Aptera, having a 120V charge port makes a good deal of sense for those who want to charge overnight at home, obtaining roughly 14 miles of charge per hour connected, which for a 10 hour charge would be a resounding 140 miles of charge. That way, an $1000-1500 L2 charger installation expense can also be avoided.
Looks like Aptera has pretty much covered all the bases as to sizes of battery packs. I personally have opted for a 60kwh pack. By careful driving I have been able to squeeze 360 miles per charge from my 2017 Bolt but with a poor drag coefficient of over .3 freeway speeds drop range by more than 100 miles.
Yeah the jump from 3 to 5 batteries seems like a lot. The single battery appears to be a 25kWh one, so why not just offer three of those for their high end.
Actually, why do they have a 20 and a 25 kWh module? They could eliminate one of the middle two sizes if they went with all 25kWh modules and just do 1, 2, or 3 to a pack. I am sure someone knows the history behind that. I would prefer a 500 mile car to a 600 mile car, I just think 400 is too small in todays market.
I agree that the 1000 mile range is overkill. Especially since so many of the environmental costs of an electric vehicle are associated with the rare earth metals in the battery. Why not go with a smaller battery? I assume it would have significant weight savings as well.
@Jonathon, if they provide an onboard charger that handles both Level 1 and Level 2 via J1772, then that would be sufficient for my needs. A CCS connector would satisfy L1, L2 *and* L3, so that would be even more forward looking and satisfy the entire set of charging needs. Shifting to the battery size topic, they've responded to comments about different battery sizes, though only at a vague level. My comment was to ensure that request is formalized as a recommendation in this Design Suggestion forum @Chuck, I did exactly that, though I doubt most people would/should attempt the same.
I bought a level 2 power station for about $500 on Amazon and hooked it up myself. If you are a home owner and have the skills you can get a permit for around $25
The charger and connector used in BEV's can accommodate L1 or L2 charging. This is standard and is done in my 2013 Chevy Volt. Aptera already has mentioned multiple battery sizes being available. I think 50 kWh is big enough and will keep the cost reasonable. I would be more interested in fast charging, such as adding 400 miles of range in less than an hour, rather than a bigger, heavier battery configuration.
