The top of the list is coasting - which is the most efficient way to use the kinetic energy stored in the moving mass; and the VW e-Golf coasts by default. Having regen integrated onto the brake pedal makes a lot of sense, since when you need to slow down, the brake pedal is the best way to modulate the speed.
Adaptive creep is another feature that I really like - EVs should start with a clean slate, and mimicking an ICE is the worst reason for making a design decision. This is something that is unique to the VW e-Golf. By default, there is no creep, but if you are in stop and go traffic, it adds a very mild creep. It goes away as soon as you go above a certain speed; which is about 20MPH. A third feature that is key for an EV design, that is also found on an e-Golf, is a direct heating windshield defroster. This is far more efficient than even a heat pump, that has to heat up air, and use a fan to blow it on the glass. This is case in point for not doing something like it is done in ICE vehicles. Their horribly inefficient engines produce so much waste heat, that blowing air on the glass is an acceptable solution. EVs though, have almost no waste heat, so they should have a better solution. Ford did direct heating defrosters in the 1970's and 80's, so we know how to do this.
The dashboard display of the Chevy Bolt EV is the best of any EV I know of. The high, median, and low range estimates are accurate and clear and very helpful. They have a "trending" bar, showing that your efficiency is trending down or up, and by how much. It also shows the kW consumption / regen rate in real time, and this is also very helpful.
The Nissan Leaf has the best charging port location, in my opinion, and they are also the only one to put a light inside it, so you can plug in at night, without fumbling around - this is so basic and simple, that I can't imagine why (almost?) nobody else does it.
Something that Mercedes has started doing in their EVs makes a lot of sense: when you plug in to a public charging station, the car has an ID number, that allows you to just start charging. No need to have a separate membership for each charging company network. Makes a lot of sense to me!
Tesla has offered to open their Super Chargers but no company wants to comply and pay a fee. Better yet is they give free destination chargers to hotels and other areas. You can get a JDapter like me and plug in any J-1772 universal plug into them .most are free to use. Over night in a Hotel gives plenty of time for a recharge. You don't need Super Charging unless your in a big hurry with no Hotel over night.
Neil, Can I change the topic to Charging and ask...
Can you educate me on EV charging, since you have a family of EVs?
Any other experiences are appreciated , as I have none.
I hope to own an Aptera someday. All I know is they will have a standard charging 110v and fast 220v option. I do not know the exact plug configuration, charging times for the latest model. We heard about the ( limited) Never Charge option. But....
1
Is it true that only Teslas can use Tesla charging stations?
Since there is no universal plug configuration for all EVs....
2
Can all other brand EVs use all non-Tesla public charging stations with their vehicle’s standard plug and/or with and adapter? That is...for both the standard 110v and fast 220v level 2 chargers?
3
Can conventional credit cards be used at public non-Tesla charging stations?
4
There are hotels that have charge stations...If you know.... is charging complementary for guest, say with a room key or is there a separate charge?
E.g., One reference:
http://www.chargehotels.com/
5
What have your found to be the best website to locate charge stations, with charging options, plug type provided, monitoring of your charge status, and easy for reserving?
https://www.plugshare.com/
5.1
Or is there an APP that works better?
https://www.evconnect.com/
For my family living here in New England, heating is key - heated seats, heated steering wheel, and heated exterior mirrors are also very important.
Having a heat pump is a very good thing - if it is integrated into the battery and electronics, that is even better.
