I love the concept of this, but what happens if it snows? The closed front wheel design and the rest hub would likely be frozen shut and be unusable at that point. Has winter treating been done, or is this a fairweather EV?
Aptera has wider track than most cars and rear wheel in the middle. What happens when there have been melting thick snow on the road and it starts to freeze? I have seen roads with iced rails on them. With Aptera your one wheel is in the ice groove and two other are travelling in the snow. I quess time will tell how that works. Other times tracks may have dry asphalt and other parts of the road are covered with ice. On narrow road you will have to give some room for on coming traffic but then your right side wheel may catch thick snow on the side of the road. That get dangerous quickly when only one of your wheel is on asphalt, one is in thick snow and rear wheel is on ice in the middle of your lane. I have seen traditional cars turning 180 degrees in blink of an eye.
I wonder if the handbrake is mechanical, & on the rear wheel.
Bingo. I'm confident the Aptera will be an excellent snow vehicle. The potential to spin it in the opposite direction on a narrow dirt road without a wide 3 point turn is there too.
Tens of millions of people drive in snow with FWD & all-wheel brakes. Many of them also with inferior/absent traction control. I can't think of any reason to believe that Aptera wouldn't be at least as good.
We all have our daily and occasional needs. Given were I live .
Primitive Roads - Although FWD is a minimum, AWD is nice sometimes in monsoon season (our second summer season) . Along with ABS. stability control and torque vectoring all appeal to me. But I don’t need the extra weight , cost nor need the 0-60 mph in 3.5 seconds. But with the 60 kWh battery, even a little hit on range will not matter with my planned occasional cross country trips
I beliveb I read 70/30 weight ratio somewhere?
The std 195 45 R 16 tires seem fine, even if they decide to use the 205 on the rear...
The Off Road package, which seems more for snow needs ... could be a nice option.
I don’t even use my AWD Intelli-traction on my mid size truck here much..,and avoid true “off road” adventures...If you are going to off road you should have a vehicle with heavy/ high ply tires, understand proper air pressure for the adventure, etc...and expect Cowboy🤠 scratches on your vehicle.
Primitive roads are fine.... I ❤️ my modes of transporation and try to respect and protect them!
Outside of this topic
Full solar makes sense in Southern AZ and the fact that it obscures light coming in through the large glas hatch is fins with me as I never use my vehicles sun/moon roofs. They just were included in the model. And there is very little of a weight hit going full solar. The solar on the hatch will provide some cargo privacy
Are you getting the AWD version? I agree with all of your points. I am going with a Paradigm, and am hopeful that it will still be ok with caution.
Add to all those Saab features: Aptera's traction control at each 1/32 of every tire revolution. Plus of course ABS.
I'm eager to drive my Aptera on our McCall Idaho roads. This is one of the snowiest towns in the country, with six months of the white stuff. My long gone SAAB 96 was a great car in snow. Why? Narrow tall tires, wheel wells designed to deflect snow, front wheel drive, light weight, and minimal body overhang beyond the wheelbase. Design considerations that are mirrored somewhat in the Aptera. Mine was the same color and year as this one.
So if it's really the underbelly that counts, note that Aptera's is 9". It should also help that there's nothing for the snow to catch on underneath, unlike any other vehicle.
When I have been stopped in the snow it's when I get highsided, the snow builds up under the car and picks me up. But that's not snow under the tires, that under the whole undercarriage. If you have the weight of a light car holding down something that is displacing just a suitcase width of snow I think you'll be in great shape.
What if you have to drive through deep snow ( such as a road that hasn't been plowed yet) say, deep enough to reach the height of the front wheel skirts? I imagine the all wheel drive and off road options combined with a good set of snow tires should make all the difference , but being such a light vehicle, could getting good traction still be an problem....?
Simple solution...skinny tires. My I-MiEV has 145 wide tires on the front and goes through the snow like it’s on rails. It weighs 2,500 lbs. and is rear wheel drive.
As for the wheel covers, it should be fine to leave them on as the tires will keep their path clear, and unlike conventional cars, they don’t articulate within the covers since the covers steer with the tires. Hitting bumps will likely knock any built up snow out as the covers are unsprung.
Snow tires will make a large difference. The state of the art traction control will also be a big plus. Snow is unlikely to build up around the wheels, because they are rejecting the waste heat of the motors.
With so much excess range capability, increasing drag a bit with a pair of high-clearance dirtbike-style fenders might be a good winter/offroad solution.
I think it would be better to pair two wheels on the rear train and put de motor inside the wheels. More stable to drive in winter season. Just like some four wheels scooters.
Has it actually been assessed for cold weather (Canadian) usability and durability?
All good explanations. Chris also mentioned in the video, even though that Black Aptera has a one piece cover, as mention above...the production will have a easy to remove two piece and the Off Road option will have a tougher cover.
(He didn’t say how much that version will increase the ground clearance)
My guess is that the normal fine grained traction control might make drifting difficult.
I've lived for years in upstate NY and had to kick the snow out of my wheel wells on all my cars at some point, sometimes a few times each winter.
Yesterday they said that the wheel skirts will be designed to clip off easily for tire changing and flat repairs. So that's an option.
It may be less of a problem than you think because the inwheel motors make enough heat that they need to be liquid cooled. That should melt any snow and ice.
However, Bojan may have it right in that the off-road kit may be just the thing for serious winter weather when people tend to play bumper cars more often.
Winter spin-outs in empty icy parking lots anyone? (May need to request a "drift mode" for this activity if the active traction grip is too good.)
Maybe the off-road kit with wintertires? One of the first SAAB had closed wheel design and it seemed to be terrible to drive in snow .
Tire would wear down the ice once you start moving like any other car. of course it will make some noise. It is designed for snow and ice with all-wheel drive with quick response tability control from controlling the motor in each wheel.
