Would it be possible for Aptera to engineer a receiver into the structure inside the rear wheel fairing to make trailering on the front wheels possible? It would be the ultimate land dinghy. I suspect the tongue weight would approach 500 lbs.
6 comments
6 Comments
I fear that the added weight and shift in balance point would make this a non starter. You would have to give up too much performance for all the times you are not towing. A towable dolly of some sort might work however.
This is interesting but it seems like one of the two options for a structure “back there” was for 1) lift point and 2) to have a hitch to pull a very light trailer
A one wheel trailer.
I think something like that could work!
How about a single caster wheel towing dolly that you just back up on, strap on and away you go.
Just let it fit in the bed of Cybertruck....
