Anyone know if the safety pilot add on impacts delivery time/group? I ordered the Paradigm 400, which appears to deliver first.... Unless add ons change the group.
I would assume any additional options can bump you up the list, Aptera is so early in the vehicles development i don't think anyone knows what add on options may delay an order. The only confirmed delay to order option is the all wheel drive.
@Daniel Watkins "they said orders would be fulfilled in this order: first 40KWh, then 60, then 25, then 100KWh orders".
Is there a 'translation' of the kWH ratings you listed to the 'mile per charge' models listed? I preordered a Paradigm 400 mile range, but I am not seeing a spec for the kWH rating for the battery pack or any kW/mile at speed 'X' to get an idea of where my order will land timing wise. I am also hoping to add the third motor to the rear wheel, but only if there are performance and driving dynamics benefits (not just acceleration).
Perhaps in some way. But in the ambassador call yesterday, they said orders would be fulfilled in this order: first 40KWh, then 60, then 25, then 100KWh orders.
I just want to clarify... Do you mean that they were going to fulfill the original "Paradigm" and "Paradigm Plus" orders, and then custom orders after starting with the 25kWh, or are they really postponing the "cheap" one until all pre-ordered 40s and 60s are done? I am not sure if you (or even Aptera!) knows for certain. Thanks!
@giannid1969 From the original Paradigm model page. "These will be the first produced in 2021." No promise on delivery times for the "Plus" An update to the FAQ page here, by them, would be in order, even if it is just an estimate. They can further update as information becomes available and the timeline becomes less fluid. (At the least, I'm sure it would cut down on the inquiries probably being regularly emailed to them.)
Daniel is right on order.But.... I believe you just drop the first two numbers “10” so you would be 716
