You teased a Tesla Connector in one of your Videos, are you trying to work out a deal with Tesla? If you are using CCS what charging speed will you support? It better be at least 150KW and preferably higher. GM is configuring the Hummer's battery pack so that the batteries can be charged in series to give it 800V charging and then operated in parallel at 400V, that's a mice approach. The key parameter is that a 20-80% charge time should take no more than 20 minutes.
For me, 50kW DC fast charge is fine for the Aptera, even if higher charge speed would be better.
But I live in France and there is a big drawback to have a slow charging car in France. Most fast charger companies do not register themself as energy provider. They are then not allowed to sell electricity and then can not sell kWh.
They then sell a charge service and will bill you per minute !! So the slower your car will charge, the more expensive it will be.
My Ioniq charges at 70kW and is one of the most efficient car today. But if I use a fast charger in France, it will be more expensive than gasoline.
Public fast and slow chargers are very expensive. Fortunately, we can charge at home most of the time, and with the Aptera, it will be a little bit cheaper to travel long distances, even with only 50kW charging rate.
I agree, 50KW may not cut it. Aptera claims 500 mi of charge per hour and the ioniq5 and the EV6 are about 700. (10-70% in 18 minutes, using 300mi range). Not enamored with tesla, they lie/stretch the truth too much, although their supercharger network is very good for long travel. That said, I'm looking at a 600m version and to be realistic I can go that long anymore without a break...
I use Abetterrouteplanner.com to plan a longer trip.
I recently drove south to Italy for a weekend gateway. Before driving back home I enjoyed breakfast on a sunny outdoor terrace while my EV was charging at a nearby public charger.
Certainly Tesla has a top notch charging network nobody gets even close to that. And Elon repeatedly said in interviews that he would let other manufacturers charge. But I guess they would have to chip in for Tesla to build even more chargers.
It sounds like your issue is more with the charging network than the charging speed. Since the Aptera is expected to be about 3 times more efficient than most Teslas on the highway, on a per mile basis 50kW charging is equivalent to 150kW charging a Tesla, so it is not as bad as it seems. Faster charging might require a larger cooling system with a radiator and fan, which would greatly hurt the aerodynamics. The 3 motor AWD version has 150kW max discharge, so the cooling system can handle that heat load, but that occurs when the vehicle is moving. The skin cooling system will be much more limited when stopped and charging.
I am puzzled. You answer your own concerns. You are happy with a 600 mile version.
One advice if you ever travel 2000 miles with your Tesla and only take 20 min human pit stops. You are a danger to all others.
We currently drive a Renault Zoe in Switzerland. It has a 50kwh battery.
At one home we have a 11kwh charger. We usually plug it in once a week. The car is always recharged way ahead of time over night. At the other home we just plug it into the regular 240V wall socket. And even there we don't have to plug it in every night. But if you did . Certainly not an issue.
Most our road trips do not require recharging as it has plenty of range. We usually charge at destination when again we spend way more time at a destination than the car needs to recharge.
The few occassions we charged on the way / pit stop using a fast charger, the car was finished recharging way ahead of us finishing our human pit stop.
Long story short if the aptera can fast charge at 50 kwh it is plenty fast.
Would you ever drive 600 miles without a human pit stop? I would not even drive 400 miles without needing a break - a break that takes more time for us than the car to recharge. Hence I opted for the 400 miles aptera.
I see they are planning on 50KW charging, that's a terrible idea and I hope they change it. With a 600 mile range top ups, which is all that 50KW is good for won't happen but on a multi day road trip without access to destination charging you will need to do 80% battery charges, at 50KW that will take forever. The rate needs to be at least 150KW. I have a reservation on the 600 miles version but if they stick with 50KW fast charging I won't buy the car. They also need to use a 32A Level 2 charging at least, it's a pretty big battery. The Volt could get away with 3.6KW charging because it only had a 14KWh usable battery, this car will have a 60KWh and 100KWh usable battery so it needs a decent charging speed. I'd be OK with 32A, I have a 32A Clipper Creek that I put in for my Volt but I appreciate the 48A rate on my Tesla.
They have not announced the final decision on this but many current replies are on their ... Aptera's FAQ Spreadsheet Please search it with Ctrl+F (for "Find"), or for Mac use command+F or cmd+F These answers are from an Aptera member !
Or just use this forum’s 🔍SEARCH function.
