This may not pertain to all of you, but what if you already need to charge multiple EV's? Or how can you share your 240 V. dryer plug with your new Aptera. No need to plan for an expensive second 240 V. line by an electrician especially if one plans to garage his Aptera.
There exist a Smart Splitter which can be used at the dryer outlet, or at your current 240 Volt plug-in EVSE which can turn on either car charger or dryer and charger selectively. So since a level 2 charger usually doesn't run for more than 6 hours, it can charge one car, then turn on the other. Similarly, once the clothes are dry, it turns on the Aptera EVSE.
https://www.getneocharge.com/shop-pages/shop-smart-splitters
Just letting the forum know of other solutions while waiting for the Aptera update.
@OceanDragon I agree it's a great option for current EVs. I was just pointing out that Aptera doesn't need it as much.
There's less need for any aftermarket L2 unit than most people seem to realize. Most OEM cords work great on 240V, so all you need is the OUTLET (that you'd need anyway for the aftermarket unit) & you get 104 miles overnight (260 in Aptera).
That DC rapid charge is great for road trips.
For daily use, "130 miles overnight from a standard wall outlet" is a game-changer, since it means nearly everyone can commute without needing to buy a 240V home charger. Current EVs recharge "only" the AVERAGE daily drive from a standard outlet in 8 hours of sleep or work. That means about half of drivers need L2.
500 mile an hour charge
I'm pretty sure the 3.3kW & 6.6kW ratings are the onboard chargers' OUTPUT to the HV drive battery, so their ~85% efficiency doesn't affect charge time. It only affects the amount of input power used.
I mean that one of the many advantages of Aptera's extreme efficiency is very low charge time. So with multiple EVs per plug (home OR public) there's not much competition over the plug like there would be with for example a Tesla X & a Jag.
So if you have multiple EVs & 1 is an Aptera you just plug it in for half an hour & then plug the less efficient one. Or the Aptera charges while you do the wash, & it's done before you need the dryer.
But really you don't even need home L2 with Aptera since it recharges about 2.5 average days' drive from a standard wall outlet in just one night's sleep.
An EV's A.C. charger is onboard, & is 1 of the things that can limit charging speed. For example my 500e's 6.6kW charger maxes out most public L2 plugs, & still charges at 6.6 on my friend's 9kW home plug. Aptera is considering a 3.3kW unit but with 2.5 times the driving efficiency it still recharges faster.
That's great, but recharging Aptera only takes 36 minutes!
(240V, std 6.6kW, US average 40-mi drive)
Even IF they go with a half speed 3.3kW onboard charger it's still only 72 minutes.
