We know lithium batteries degrade faster when they are charged over 80% and discharged below 20%. Will there be a way to limit charging percentage to a user customizable percentage? It would be especially advantageous if any extra charge over the set amount could be directed to conditioning the cabin, or with V2G, sent to the grid.
Programmable charge level would be useful for other reasons. GM's charge limiting feature is called "hilltop reserve" and intended for people who live on top of a hill, to leave room for regenerative braking. And Aptera owners would probably want to leave room for solar charging, e.g. if you only drive a few miles to work and leave the car in an outdoor parking lot all day.
Actually, we don't "know" that Li batteries degrade faster when charged above 80% or discharged below 20%. What we know is that automotive traction battery packs, when regularly charged with DC current to 100% of capacity, are more likely to be stressed and will, possibly, lose capacity more quickly than those that are not. Li cells that are allowed to discharge to 0% are likely to undergo internal chemical changes and might not be able to be recharged completely. This is why all automotive traction battery packs have a nominal capacity and an actual capacity: Up to 20% at both the top and bottom of a pack's capacity is "locked-off" by the manufacturer and cannot be accessed by the user. For example, the Li pack in a Honda Clarity PHEV is advertised as being 17 kWh - but only 13 kWh is available for use. Tesla, because of its robust battery chemistry and massive amounts of operating data, has - on several occasions - increased the range of its vehicles by unlocking some of the hidden capacity. Also, if an EV is plugged into a Level 2 EVSE or DC charger, power for cabin conditioning will be drawn from the grid, not from the pack.
