im in Michigan and we get plenty of snow here. I'm imagining the difficulty driving through fresh snow in the center of the road. I am imagining a removable spring loaded plow to scoop away snow before driving hough it.
2 comments
2 Comments
I imagine the traction of all three wheels with computer controlled instantaneous tractions control, this car will do as well as any front wheel car if not better.
I'm in New England, and we get a lot of snow here, too. Driving any car in fresh snow, or that has a different track width than the first vehicle - or on a different path than the first vehicle, will be the same as driving the Aptera. On this current design, having all 3 wheels powered - with traction control, it won't be a problem.Winter tires are a must, for any vehicle driven in snow - 2WD, 4WD, or AWD without winter tires, don't cut it. With good winter tires, then fresh snow is better than with any number of driven wheels.And the snow plows and sand / salt trucks do clear things up, eventually.
I'm in New England, and we get a lot of snow here, too. Driving any car in fresh snow, or that has a different track width than the first vehicle - or on a different path than the first vehicle, will be the same as driving the Aptera. On this current design, having all 3 wheels powered - with traction control, it won't be a problem. Winter tires are a must, for any vehicle driven in snow - 2WD, 4WD, or AWD without winter tires, don't cut it. With good winter tires, then fresh snow is better than with any number of driven wheels. And the snow plows and sand / salt trucks do clear things up, eventually.
