On your description I noticed that your solar cells are placed to totally obscure the rear view of the driver. Why not place them on louvers instead? You know, something like what Deloreans had over their back windows in the past? Covering the rear window with a louvered set of horizontal "shelves" will shade the interior, allow the driver to see out the back with no difficulty, and allow a flatter surface and thus a more efficient and denser placement of the solar cells. I am uncertain of the aerodynamic cost of louvered rear hatches, but since the planes are in line with the air stream, I'm betting that the effect will be minimal or perhaps even beneficial!
If solar panels mounted on exterior louvers are problematic, interior louvers would also work and maintain the stock aerodynamics. I'm betting that allowing rearview mirror sight out of the rear window would outweigh a small aerodynamic drag (exterior) or loss of interior volume (interior).
A lot of non engineer, non production, and non costing people comments here. I support keep it simple and no engineering changes in the first production model. Let's trust the team who have done a stellar job with limited budget and staffing resources to get a version out the door that can generate revenue for the company. Then the analysis can take place on which enhancements most customers want vs. the time and resources to incorporate them and the amount of revenue they will generate. Remember this is a business that needs to sustain operations through revenue generation and profit. If you do not like the current design you do not have to get full solar and can wait for a third party or the next iteration of Aptera to incorporate some of these ideas based on a tradeoff of idea vs. cost. vs. effort vs. market appeal.
I eventually found this Aptera forum after watching an investment Youtube channel. They also did a segment on Solar Window Technologies https://www.youtube.com/watch?v=LQHcTSn3Ync where they claim they can"TRANSFORM ORDINARY SURFACES INTO ELECTRICITY GENERATING PRODUCTS" Would Aptera reach out to see if their product might work here? I hope so
Nice! Likely even no plug needed just for cleaning. Like the hatch itself, hinge at the top by the wires: Open the hatch, release 2 clips & the louvers pivot down for cleaning.
Maybe make each louver 2-cells wide, for easy cleaning.
EDIT: FOR 2024 MODEL!!! (except in the unlikely event it won't delay production of the current model)
A simple connector and some 1/4 turn fasteners would make the louvers easily removable.
It must still worth it since the base model Aptera comes standard with interior solar.....
on the dashboard, inside the windshield.
I had interior louvers on my 240Z & they didn't get dusty, even though there was no cabin air filter.
My engineering sense says keep it simple. The louvers are going to add cost and I think spoil aerodynamics. Even cleaning that area is more complicated.
what would it do to the drag coefficient?? i would think that would change with putting those panels on the back.
There is a passive tracking technique used on solar panels that uses heat from the sun to expand gas in sealed cylinders causing the panel to track the sun's movement. It could be left to do this when the car is parked to maximize solar gain, and then set for maximum visibility when the car is started.
The solar panels are most effective when the angel of the sun rays is perpendicular to the panels. This might be achieved with a sensor and adjustable suspension of the (rear) wheel(s).
solar would loose as much direct sunlight coming from certain angles at different times of day, current curved angle allow friendliness to more angles, but the most productive sunlight comes near midday rather than near sunrise/sunset for lands with not much elevation and elevation change, solar isnt very productive so any bit of sunlight adds up...
energy savings from not having a camera and display system constantly running helps the case for it, although camera is good to have as explained: https://www.aptera.us/forum/main/comment/60777af5624384001581ea10
I am seeing a boat load of vortices (vortcii?) rolling off of the back of each louver. On one level, I think this is a genius idea, but I think it is probably highly disruptive to the aerodynamics. It's hard enough to stay laminar on the trailing surface of the car as it is. It would be nice to hear from Aptera's aerodynamicist on this idea.
Great idea. The solar cells are at different angles to optimize power generation. I wonder if this would require a rework of the angle pattern on the louvers. Wide enough for.solar cell pattern? Wiring?
