I've seen several "complaints" about the width of Aptera's front tires. I just saw a different auto Triggo | Electric car. At lower speeds, this car will allows the tires to move inward. Seems like a good Idea to me. I would probably only want it for when getting ready to park or other low speed areas since it would reduce stability. Looks like a winner idea to me. I need the extra space in my garage and it would probably take a lot less damage in parking lots.
A Triggo is on my short list of alternatives to Aptera purchase if the width remains prohibitive to getting through single garage door.
I think this discussion has gotten off track.
This discussion was suggested as a Parking issue and I do not plan to drive the car with the tires tucked in. People seemed to be worried about the left wheel being extended too far when parking on streets or parking lots. The reduced width would make it a nicer fit in the garage as well.
Personally, the changing the tire housing to be more Bike Like just looks cheap. It makes me think of something thrown together in some diy garage.
@Ken Kobayashi
Forget the 10%, it's not worth the discussion, a discussion about the emperor's beard 🤓
https://www.aptera.us/forum/general-discussions/width-for-eu-gives-900-mi-range
Why are we still arguing about this? Aptera has repeatedly said that the wide track is for aerodynamics. If the gap between the wheel pod and the body is decreased, air resistance goes up. And they have made a decision to prioritize efficiency over size, at least for the initial roadster model.
@kiteboarder
This info is only for kite-boarders, has to do with technology, but not related to Aptera
Thank you for proving my point. As shown in the vid I linked, Aptera was engineered to slide SO far before the point of instability (even with no anti-sway bar AND the higher CG motor, tranny & diff) that with its new lower CG it can certainly stand to lose enough front track to make it legal in Europe.
@OceanDragon Please feel completely free to attempt an explanation. If it's beyond my modest education, I.Q., & half-century of studying automotive handling physics, I'm sure someone else here will be happy to respond.
BTW, is the 3 wheeled "bike" to which you refer an unstable delta or stable tadpole?
P.S. Polaris Slingshot. Can-Am Spyder.
@OceanDragon Sorry, but:
1) Incorrect:
Compared to 1 front wheel, Aptera's 2 front wheels is extremely stable, as seen easily in this old vid with the high center of gravity central motor, gearbox & differential (all deleted, for lower center of gravity on the current model).
2) Incorrect:
Aptera's illegal front wheel track can be narrowed to the legal limit without narrowing the cabin or increasing turning radius, simply using their prior fenders which retain a minimum range of about FIVE TIMES the average US daily drive:
3) Correct: variable-width would add some extra weight (& cost), & naming unavailable vehicles doesn't really help.
@Jeff Petsinger
Order another Aptera right away, for spare parts provisioning 😁
Without looking at it, the mechanism sounds complicated and heavy. With that said, I am genuinely worried about pulling this through a single car garage door without eventually scraping the wheel pants. They need to do something.
