With this being an autocycle does that still remain an auto for licensing or does it det classified as a motorcycle that it would require a motorcycle license? The promos note it's closer to a motorcycle in design, but functionally it drives like a car.
Also is there any type of solar credit/emissions rebate that the government plans to do or has as an incentive for people to switch to these?
On the pet package can more specifics or a photo of the set up with the divider, etc be provided? Is it removable for when the pet isn't in the car for extended periods (i.e. vet transport only) and dimensions for the space/size of the dog that would fit?
On the solar panels, does it obscure view? E.g. back panel would block out visibility or is it still viewable. Eventually we may get one for our daughter who us presently 15, but the add on for that section would depend on viewability for her as a new driver. Also along same lines of solar panel, will there be an open sunroof option at some point and if so when it retracts would it still be able to have the solar panel so that winter time and when it's closed there would still be the solar panel ability for that car on the top section or do you forsee this as it would be an OR option of sunroof or solar panel but doesn't work to have both with the mechanics. Wouls sunroof add significant drag if it recessed into car rather than the kind that lifts and doesn't retract that obviously would add drag?
Bruce’s answers are what I understand too
Three solar configurations and this is a pet kit rendering someone placed in a blog?
There will be a rear view on the rear view display, captured by the body cameras
A $30 discount for your daughter’s
reservation:
Code below for $30 off refundable deposit:
The State license plate will be for an autocycle or motorcycle. In most states you can use a standard automotive driver's licence. I don't expect that we will see an opening sunroof option anytime soon., mainly because it might raise the air resistance when it is open, and decrease the integrity of the roof in a crash. With full solar, the rear window is covered and a camera replaces the view to the back.
