If V2G is not going to be a capability for the initial production vehicles, can there at least be a way of routing the power from the vehicle's solar panels to a home power storage system? This should be a no-brainer, easy thing to implement...
https://www.aptera.us/forum/main/comment/602d8ee7c0b097001746420d
Okay, & I did go off-track to direct V2H, so without any "ifs":
You asked for "a way of routing the power from the vehicle's solar panels to a home power storage system". For sure, you can do either of these two options for that:
- Tap 12V off the battery terminals, & with the key on, that runs off the car's solar-charged HV drive battery.
- Tap 120V off the 12V terminals with a pure-sine inverter, available at Amazon for $200 (1.5kW continuous, 3kW peak for fridge-startup, 300+ 4.5-star reviews).
A bit of motor-starting peak power that's more than the car's DC-DC converter will just drain the 12V battery a bit & be replenished later.
Hi kiteboarder:
That's a lot of "ifs". I want a statement from Aptera on a REAL capability which I can plan on.
Seems to me easy enough to implement yourself. BEVs can run appliances in power outages from an inverter connected to the 12V battery, with the car turned on to activate its DC-DC converter.
Aptera says they're testing a 1.5kW DC-DC converter that powers the 12V system from the HV drive battery. IF that allows you to pull 1.5kW from an inverter, that's enough to simultaneously run my fridge, TV, computer & monitor.
I'd have to shut most of them off for a couple minutes to run my 1.3kW microwave though, or longer to charge another 1.4kW EV. However, there are lower-power microwaves, & I also heard about an EVSE with a switch for lower power use.
